Ana içeriğe geç
HP Pavilion dv7-1285dx RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-1285dx RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx RAM Replacement, Back Plate: adım 2, 1 resimden 1.
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx RAM Replacement: adım 3, 2 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Rotate the device 90 degrees to the left.
  5. HP Pavilion dv7-1285dx RAM Replacement: adım 5, 3 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 5, 3 resimden 2. HP Pavilion dv7-1285dx RAM Replacement: adım 5, 3 resimden 3.
    • Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
  6. HP Pavilion dv7-1285dx RAM Replacement: adım 6, 3 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 6, 3 resimden 2. HP Pavilion dv7-1285dx RAM Replacement: adım 6, 3 resimden 3.
    • Unplug the RAM.
    • Repeat step 6 to remove the second piece of RAM.
  7. HP Pavilion dv7-1285dx RAM Replacement: adım 7, 2 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 7, 2 resimden 2.
    • These steps are important in the replacement of the RAM, they will assist in ensuring the device is not damaged.
    • Align the notch in the new RAM with the peg on the plug
    • Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
  8. HP Pavilion dv7-1285dx RAM Replacement: adım 8, 2 resimden 1. HP Pavilion dv7-1285dx RAM Replacement: adım 8, 2 resimden 2.
    • Push down gently on the RAM until the grey clips click.
    • Repeat steps 7 and 8 to replace the second piece of RAM.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jesse Quisido
489 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G34
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,147
