Ana içeriğe geç
HP Pavilion dv7-1285dx Wifi Card Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-1285dx Wifi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Wifi Card Replacement, Back Plate: adım 2, 1 resimden 1.
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 3, 2 resimden 1. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx Wifi Card Replacement, Wifi Card: adım 4, 1 resimden 1.
    • Locate the wifi card to the right of the RAM.
  5. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 5, 1 resimden 1.
    • Unplug antenna cables 1 and 2 from their leads.
    • Antenna cable 3 is not used.
  6. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 6, 1 resimden 1.
    • Remove the two Phillips head screws located on the battery compartment side of the wifi card.
  7. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 7, 1 resimden 1.
    • Gently lift the wifi card up to a 45 degree angle from the side with screws.
  8. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 8, 2 resimden 1. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 8, 2 resimden 2.
    • Unplug the wifi card.
  9. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 9, 1 resimden 1.
    • These next steps are for installing your replacement wifi card. These steps are very important to ensure that you do not damage your device.
    • Fully insert the replacement wifi card at a 45 degree angle, ensuring that the notch on the card lines up with the peg on the plug.
  10. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 10, 1 resimden 1.
    • Gently push the wifi card down until the screws can be replaced.
  11. HP Pavilion dv7-1285dx Wifi Card Replacement: adım 11, 1 resimden 1.
    • Connect the antenna cable 1 with lead 1 and connect antenna cable 2 with lead 2.
    • Wire 1 needs to be connected to lead 1 and wire 2 needs to be connected to lead 2.
    • Wire 3 and lead 3 are not used.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anmol Mathur
291 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G34
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 2,157
