Ana içeriğe geç
HP Pavilion dv7-1448dx Key Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-1448dx Key Replacement, Key: adım 1, 1 resimden 1.
    • Make sure the computer is unplugged and turned off.
    • Open the laptop so that the keyboard is fully exposed.
  2. HP Pavilion dv7-1448dx Key Replacement: adım 2, 1 resimden 1.
    • Place the plastic opening tool in the crevice near the key that needs to be removed.
    • This works best if the tool is placed at the top of the key.
  3. HP Pavilion dv7-1448dx Key Replacement: adım 3, 1 resimden 1.
    • Gently lever the tool downward until the key tilts upward.
    • At this point, move the tool around in order to completely pry the key off the keyboard. As the key is removed, small pops will be heard.
    • This step may take longer for larger keys.
    • When reinserting the key, gently press down until 2 clicks are heard (4 for larger keys).
  4. HP Pavilion dv7-1448dx Key Replacement: adım 4, 1 resimden 1.
    • Carefully remove the key from the base.
  5. HP Pavilion dv7-1448dx Key Replacement: adım 5, 1 resimden 1.
    • If the issue is a sticky key, make sure to clean the area once it is removed.
    • Use a cotton swab with alcohol to clean the underside of the key and the key slot.
Sonuç
Kirsten Gilliland
741 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 3-5, Whitney Spring 2017 Baylor, Team 3-5, Whitney Spring 2017 üyesi
BU-WHITNEY-S17S3G5
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 395
