Ana içeriğe geç
HP Pavilion dv7-3065dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion dv7-3065dx Hard Drive Replacement: adım 3, 2 resimden 2.
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Hard Drive Replacement: adım 5, 1 resimden 1.
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Gabi Marino
157 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Wilder Spring 2017 Ohio State, Team 1-5, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 3,526
