Ana içeriğe geç
HP Pavilion dv7-4285dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-4285dx Hard Drive Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion dv7-4285dx Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery release switch to the left. The battery pack will then subsequently release.
  2. HP Pavilion dv7-4285dx Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the battery pack from the socket.
  3. HP Pavilion dv7-4285dx Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. HP Pavilion dv7-4285dx Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. HP Pavilion dv7-4285dx Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Unscrew the 5 back plate screws using a Phillips #0 screwdriver.
    • During the removal process, the back plate will retain the 5 back plate screws.
    • Remove back plate using a metal spudger.
  4. HP Pavilion dv7-4285dx Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion dv7-4285dx Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the four 5.7 mm screws, holding down the hard drive, using a Phillips #0 screwdriver.
  5. HP Pavilion dv7-4285dx Hard Drive Replacement: adım 5, 3 resimden 1. HP Pavilion dv7-4285dx Hard Drive Replacement: adım 5, 3 resimden 2. HP Pavilion dv7-4285dx Hard Drive Replacement: adım 5, 3 resimden 3.
    • Pull up carefully on tab hooking the hard drive to the mother board.
    • Remove the hard drive.
Sonuç
Austin Sandel
363 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Baechle Fall 2018 IUPUI, Team S1-G2, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 798
