Ana içeriğe geç
HP Pavilion dv7-6163us Touchpad Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-6163us  Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over so that the bottom is facing up.
  2. HP Pavilion dv7-6163us  Touchpad Replacement: adım 2, 1 resimden 1.
    • Place your finger on the battery release latch and slide it to the right to release the battery.
    • The battery will pop up after sliding the latch.
  3. HP Pavilion dv7-6163us  Touchpad Replacement: adım 3, 1 resimden 1.
    • Firmly grasp the battery and remove it from the device.
  4. HP Pavilion dv7-6163us  Touchpad Replacement, Touchpad: adım 4, 2 resimden 1. HP Pavilion dv7-6163us  Touchpad Replacement, Touchpad: adım 4, 2 resimden 2.
    • Remove service door by prying the plastic opening tool or the spudger under the door.
    • Lift door and set aside.
  5. HP Pavilion dv7-6163us  Touchpad Replacement: adım 5, 3 resimden 1. HP Pavilion dv7-6163us  Touchpad Replacement: adım 5, 3 resimden 2. HP Pavilion dv7-6163us  Touchpad Replacement: adım 5, 3 resimden 3.
    • Remove the single screw securing the optical drive in place.
    • Detach the optical drive by sliding your fingers between the drive and the body of the laptop.
    • Pull out the optical drive.
  6. HP Pavilion dv7-6163us  Touchpad Replacement: adım 6, 1 resimden 1.
    • Remove all visible screws:
    • Remove the four 10 mm screws (one at each corner).
    • Remove the remaining twenty-five 3 mm screws.
  7. HP Pavilion dv7-6163us  Touchpad Replacement: adım 7, 3 resimden 1. HP Pavilion dv7-6163us  Touchpad Replacement: adım 7, 3 resimden 2. HP Pavilion dv7-6163us  Touchpad Replacement: adım 7, 3 resimden 3.
    • Turn the laptop right side up and open the screen.
    • Use the plastic opening tool to loosen and remove the keyboard. Begin in the middle top of the keyboard and work around the edges.
    • The keyboard will snap out, but do not remove it completely. It is still attached to the device by a ribbon cable.
  8. HP Pavilion dv7-6163us  Touchpad Replacement: adım 8, 2 resimden 1. HP Pavilion dv7-6163us  Touchpad Replacement: adım 8, 2 resimden 2.
    • Flip up the keyboard to access the ribbon cable underneath.
    • Disconnect the keyboard ribbon cable from the motherboard.
    • Remove the keyboard.
  9. HP Pavilion dv7-6163us  Touchpad Replacement: adım 9, 3 resimden 1. HP Pavilion dv7-6163us  Touchpad Replacement: adım 9, 3 resimden 2. HP Pavilion dv7-6163us  Touchpad Replacement: adım 9, 3 resimden 3.
    • Release the faceplate with your fingers or a spudger. Begin at the top left corner and work your way around to snap the faceplate away from the body of the laptop.
    • Turn over the face plate to access the underside of the touchpad.
  10. HP Pavilion dv7-6163us  Touchpad Replacement: adım 10, 3 resimden 1. HP Pavilion dv7-6163us  Touchpad Replacement: adım 10, 3 resimden 2. HP Pavilion dv7-6163us  Touchpad Replacement: adım 10, 3 resimden 3.
    • Disconnect three ribbon cables.
    • Remove the eight screws securing the touchpad plate.
    • Remove the touchpad plate.
  11. HP Pavilion dv7-6163us  Touchpad Replacement: adım 11, 3 resimden 1. HP Pavilion dv7-6163us  Touchpad Replacement: adım 11, 3 resimden 2. HP Pavilion dv7-6163us  Touchpad Replacement: adım 11, 3 resimden 3.
    • Pop out the touchpad using a plastic opening tool. The edges should snap out of place.
    • Remove the touchpad.
Sonuç
Kaylee Cort
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 1,016
