Giriş
Having trouble charging your computer? Does your device have an unusually short battery life? You may need to replace your battery. Most batteries will eventually burn out and the lifetime of the battery will shorten. Often, batteries can burn out due to a power surge or being overcharged . When a battery burns out, it will need to be replaced.
Move this slider to the left, towards the battery icon.
The battery will then pop out, and you will be able to remove and replace it with no difficulty.
Bir başkası bu kılavuzu tamamladı.
