Ana içeriğe geç
HP Pavilion dv7-6178us Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us Hard Drive Replacement: adım 2, 1 resimden 1.
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  3. HP Pavilion dv7-6178us Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion dv7-6178us Hard Drive Replacement: adım 3, 2 resimden 2.
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zach Lunghi
148 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 UMass Dartmouth, Team S4-G8, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S4G8
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
This is a really GREAT thing that's being done!
It's high time that consumers fought back and stop letting the TECHNO-OVERLORDS, collectively STRIP us of the right to use the digital tools that we purchase from them.
Walter D Wormack - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 48
Her zaman: 1,760
