Ana içeriğe geç
HP Pavilion dv7-6178us RAM Replacement
  1. HP Pavilion dv7-6178us RAM Replacement, RAM: adım 1, 2 resimden 1. HP Pavilion dv7-6178us RAM Replacement, RAM: adım 1, 2 resimden 2.
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us RAM Replacement: adım 2, 1 resimden 1.
    • Locate the RAM and push the two tabs on the sides away from the RAM.
  3. HP Pavilion dv7-6178us RAM Replacement: adım 3, 1 resimden 1.
    • Once the tabs on the sides are released the RAM card will pop out by itself to this angle, as shown in the picture.
  4. HP Pavilion dv7-6178us RAM Replacement: adım 4, 1 resimden 1.
    • Pull the card out of the socket and you have successfully removed one RAM card.
  5. HP Pavilion dv7-6178us RAM Replacement: adım 5, 2 resimden 1. HP Pavilion dv7-6178us RAM Replacement: adım 5, 2 resimden 2.
    • Steps 2 through 4 can also be done on the second RAM card, located directly below the initial RAM card.
Sonuç
Branden Simas
178 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 UMass Dartmouth, Team S4-G8, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S4G8
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 605
