Ana içeriğe geç
HP Pavilion dv7t-7000 CD Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7t-7000 CD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 CD Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 CD Drive Replacement: adım 3, 1 resimden 1.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 CD Drive Replacement, Back Panel: adım 4, 1 resimden 1.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 CD Drive Replacement: adım 5, 2 resimden 1. HP Pavilion dv7t-7000 CD Drive Replacement: adım 5, 2 resimden 2.
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 CD Drive Replacement, CD Drive: adım 6, 2 resimden 1. HP Pavilion dv7t-7000 CD Drive Replacement, CD Drive: adım 6, 2 resimden 2.
    • Remove the single Phillips #00 screw.
  7. HP Pavilion dv7t-7000 CD Drive Replacement: adım 7, 2 resimden 1. HP Pavilion dv7t-7000 CD Drive Replacement: adım 7, 2 resimden 2.
    • Pull CD drive out to remove.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 144
