Ana içeriğe geç
HP Pavilion dv7t-7000 Palm Rest Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7t-7000 Palm Rest Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 2, 1 resimden 1.
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 3, 1 resimden 1.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Palm Rest Replacement, Back Panel: adım 4, 1 resimden 1.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 5, 2 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 5, 2 resimden 2.
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Palm Rest Replacement, RAM: adım 6, 2 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement, RAM: adım 6, 2 resimden 2.
    • Push the retraining springs away from the RAM at the same time to unlock the RAM.
  7. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 7, 2 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 7, 2 resimden 2.
    • Pull the RAM out.
    • Follow the same procedure for the additional RAM.
  8. HP Pavilion dv7t-7000 Palm Rest Replacement, Wi-Fi Card: adım 8, 2 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement, Wi-Fi Card: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to pop off the antenna connectors.
  9. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 9, 3 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 9, 3 resimden 2. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 9, 3 resimden 3.
    • Remove single Phillips #00 screw.
    • Pull the card out by hand.
  10. HP Pavilion dv7t-7000 Palm Rest Replacement, Keyboard: adım 10, 2 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement, Keyboard: adım 10, 2 resimden 2.
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  11. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 11, 3 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 11, 3 resimden 2. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 11, 3 resimden 3.
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  12. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 12, 1 resimden 1.
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  13. HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: adım 13, 3 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: adım 13, 3 resimden 2. HP Pavilion dv7t-7000 Palm Rest Replacement, Palm Rest: adım 13, 3 resimden 3.
    • Flip the keyboard back over.
    • Remove the single Phillips #00 screw holding in the CD drive.
    • Pull out the CD drive.
  14. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 14, 1 resimden 1.
    • Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
  15. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 15, 2 resimden 1. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 15, 2 resimden 2.
  16. HP Pavilion dv7t-7000 Palm Rest Replacement: adım 16, 1 resimden 1.
    • Remove the panel by lifting it up.
Sonuç
Afnan
289 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 246
