Ana içeriğe geç
HP Pavilion dv7t-7000 Speaker Replacement
Neye ihtiyacın var
  1. HP Pavilion dv7t-7000 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Speaker Replacement: adım 2, 1 resimden 1.
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Speaker Replacement: adım 3, 1 resimden 1.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Speaker Replacement, Back Panel: adım 4, 1 resimden 1.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Speaker Replacement: adım 5, 2 resimden 1. HP Pavilion dv7t-7000 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: adım 6, 2 resimden 1. HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: adım 6, 2 resimden 2.
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Speaker Replacement: adım 7, 3 resimden 1. HP Pavilion dv7t-7000 Speaker Replacement: adım 7, 3 resimden 2. HP Pavilion dv7t-7000 Speaker Replacement: adım 7, 3 resimden 3.
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Speaker Replacement: adım 8, 1 resimden 1.
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  9. HP Pavilion dv7t-7000 Speaker Replacement, Speaker: adım 9, 3 resimden 1. HP Pavilion dv7t-7000 Speaker Replacement, Speaker: adım 9, 3 resimden 2. HP Pavilion dv7t-7000 Speaker Replacement, Speaker: adım 9, 3 resimden 3.
    • Use Phillips #00 to unscrew the screw and take off the front panel.
  10. HP Pavilion dv7t-7000 Speaker Replacement: adım 10, 2 resimden 1. HP Pavilion dv7t-7000 Speaker Replacement: adım 10, 2 resimden 2.
    • The speaker is located at the back side of the front panel.
    • Unscrew two screws located at the speaker.
  11. HP Pavilion dv7t-7000 Speaker Replacement: adım 11, 1 resimden 1.
    • Pull out the speakers to remove.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 1,328
