Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
In an age where files expand to huge sizes, it becomes necessary to have a large storage medium. Replacing a hard drive could be a challenging task, but this guide clarifies all potential issues.
Parçalar
Hiçbir parça belirtilmedi.
  1. Turn the laptop over to expose the bottom side.
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. Slide the switch all the way to the left to release the battery.  The battery should pop up. Lift the battery out.
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. There are two hard drive bays.
    • There are two hard drive bays.
    • Hard drive bay 1 is in the lower right corner.
    • Hard drive bay 2 is in the lower left corner.
  4. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. To remove hard drive 1 from bay 1 Using a Phillips #1 screwdriver, remove the two 5 mm screws that hold the bay 1 cover in place.
    • To remove hard drive 1 from bay 1
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws that hold the bay 1 cover in place.
    • The screws should remain in the cover.
  6. After removing the two cover screws, lift and slide the cover out of position to access the hard drive. Grab the clear plastic pull tab on top of the hard drive to lift the hard drive from the laptop.
    • After removing the two cover screws, lift and slide the cover out of position to access the hard drive.
    • Grab the clear plastic pull tab on top of the hard drive to lift the hard drive from the laptop.
  7. To remove hard drive 2 from bay 2. Most laptops don't have a second hard drive.  If yours does not, then proceed to the next step. Using a Phillips #1 screwdriver remove the two 5 mm screws that hold the bay 2 cover in place.
    • To remove hard drive 2 from bay 2.
    • Most laptops don't have a second hard drive. If yours does not, then proceed to the next step.
    • Using a Phillips #1 screwdriver remove the two 5 mm screws that hold the bay 2 cover in place.
    • Grab the clear plastic pull tab on top of the hard drive, and lift the hard drive from the laptop.
  8. After the hard drive has been removed from the laptop, it must then be removed from its bracket. Start by gently pulling the HP hard drive adapter from the end of the hard drive. Using a Phillips #1 screwdriver, remove the four 3 mm bracketing screws on both sides of the hard drive bracket (2 per side) .
    • After the hard drive has been removed from the laptop, it must then be removed from its bracket.
    • Start by gently pulling the HP hard drive adapter from the end of the hard drive.
    • Using a Phillips #1 screwdriver, remove the four 3 mm bracketing screws on both sides of the hard drive bracket (2 per side) .
    • Lift the hard drive from its metal bracket.
    • Be careful not to touch the green underside as this may damage the hard drive.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Robby Cabri
172 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G32
4 Üyeler
6 adet Kılavuz yazıldı
4 Yorum
Hello. In step 7 of the above, what is the name/part number/ size etc of the adapter/connector please ? I need one urgently.
Thanks.
freeflyshannon - Yanıt
yes that would be very helpfull because the new SSdrive I have will not fit even though is is the same size. I think I need some sort of an adaptor as you say.
Stephen Cox - Yanıt
For modern SATA SSDs, the typical form factor is 7.5mm. The standard for laptop HDDs is 9.5mm. You will need to buy a plastic spacer in order to properly mount the drive inside your computer.
Michael - Yanıt
thanks for the help
Stephen Cox - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 18
Son 30 gün: 47
Her zaman: 7,216
