Ana içeriğe geç
HP Pavilion dv9000 Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion dv9000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Keyboard Replacement, Battery Removal: adım 2, 2 resimden 1. HP Pavilion dv9000 Keyboard Replacement, Battery Removal: adım 2, 2 resimden 2.
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. HP Pavilion dv9000 Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Remove the six 5 mm screws in the battery compartment using Phillips #1 screwdriver.
    • Remove the 7mm keyboard screw located towards the center of the laptop with a Phillips #1 screwdriver.
  4. HP Pavilion dv9000 Keyboard Replacement: adım 4, 1 resimden 1.
    • Flip the laptop over and open the lid.
    • Lift out the plastic panel containing the power button and flip it over.
    • Be careful, the panel is still attached by a small ribbon cable.
  5. HP Pavilion dv9000 Keyboard Replacement: adım 5, 3 resimden 1. HP Pavilion dv9000 Keyboard Replacement: adım 5, 3 resimden 2. HP Pavilion dv9000 Keyboard Replacement: adım 5, 3 resimden 3.
    • Locate the ribbon cable attached to the underside of the plastic panel.
    • Using a spudger, unplug the ribbon cable by pushing the brown tab away from circuit board and sliding the ribbon out with your hand.
    • Set the plastic panel aside.
  6. HP Pavilion dv9000 Keyboard Replacement: adım 6, 3 resimden 1. HP Pavilion dv9000 Keyboard Replacement: adım 6, 3 resimden 2. HP Pavilion dv9000 Keyboard Replacement: adım 6, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove the three 5mm screws holding the keyboard in place.
    • Carefully lift the keyboard up (no more than a few cm) and slide it forward, towards the laptops monitor to reveal another larger ribbon cable.
    • Be extremely careful as the keyboard is still attached to the computer by the larger ribbon cable.
  7. HP Pavilion dv9000 Keyboard Replacement: adım 7, 3 resimden 1. HP Pavilion dv9000 Keyboard Replacement: adım 7, 3 resimden 2. HP Pavilion dv9000 Keyboard Replacement: adım 7, 3 resimden 3.
    • Use a spudger to push the black tab forward and slide it away from the white connector.
    • Gently pull the ribbon cable from the connector housing.
    • Remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Erik Hoffnagle
768 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G32
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Please I have a problem with my hp laptop the keyboard and there is noise on it, repair it automatic. thanks you
Clement Glah - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 3,187
