Ana içeriğe geç
HP Pavilion dv9000 RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion dv9000 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: adım 2, 2 resimden 1. HP Pavilion dv9000 RAM Replacement, Battery Removal: adım 2, 2 resimden 2.
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: adım 3, 3 resimden 1. HP Pavilion dv9000 RAM Replacement, RAM: adım 3, 3 resimden 2. HP Pavilion dv9000 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: adım 4, 3 resimden 1. HP Pavilion dv9000 RAM Replacement: adım 4, 3 resimden 2. HP Pavilion dv9000 RAM Replacement: adım 4, 3 resimden 3.
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Erik Hoffnagle
768 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G32
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 3,557
