Ana içeriğe geç
HP Pavilion dv9000 Wireless Card Replacement
Neye ihtiyacın var
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: adım 2, 2 resimden 1. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: adım 2, 2 resimden 2.
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 1. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 2. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 3.
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: adım 4, 3 resimden 1. HP Pavilion dv9000 Wireless Card Replacement: adım 4, 3 resimden 2. HP Pavilion dv9000 Wireless Card Replacement: adım 4, 3 resimden 3.
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: adım 5, 2 resimden 1. HP Pavilion dv9000 Wireless Card Replacement: adım 5, 2 resimden 2.
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Erik Hoffnagle
768 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G32
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 3,960
