Ana içeriğe geç
HP Pavilion g4-1117dx Motherboard Replacement
Neye ihtiyacın var
  1. HP Pavilion g4-1117dx Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Motherboard Replacement, L-Shaped Back Panel: adım 3, 1 resimden 1.
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Motherboard Replacement: adım 4, 1 resimden 1.
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Motherboard Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Motherboard Replacement, Larger Back Panel: adım 6, 1 resimden 1.
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Motherboard Replacement: adım 8, 2 resimden 1. HP Pavilion g4-1117dx Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Motherboard Replacement: adım 9, 1 resimden 1.
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Motherboard Replacement: adım 10, 1 resimden 1.
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Motherboard Replacement, Motherboard: adım 11, 2 resimden 1. HP Pavilion g4-1117dx Motherboard Replacement, Motherboard: adım 11, 2 resimden 2.
    • In lower left hand corner, pull on black tab to unplug the disc drive.
  11. HP Pavilion g4-1117dx Motherboard Replacement: adım 12, 2 resimden 1. HP Pavilion g4-1117dx Motherboard Replacement: adım 12, 2 resimden 2.
    • In upper left hand corner, unplug the large black electrical tape covered laptop plug.
Sonuç
Robert Hamilton
1.165 İtibar
10 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 UMass Dartmouth, Team S2-G7, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G7
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,187
