Ana içeriğe geç
HP Pavilion g4-1117dx Screen Replacement
Neye ihtiyacın var
  1. HP Pavilion g4-1117dx Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Screen Replacement, Screen: adım 3, 3 resimden 1. HP Pavilion g4-1117dx Screen Replacement, Screen: adım 3, 3 resimden 2. HP Pavilion g4-1117dx Screen Replacement, Screen: adım 3, 3 resimden 3.
    • Remove two triangular shaped screw covers in the bottom corners of the monitor near the hinges.
    • Unscrew the two 4.0 mm JIS #0 screws holding the hinge covers.
  3. HP Pavilion g4-1117dx Screen Replacement: adım 4, 1 resimden 1.
    • Pry off the monitor border cover.
  4. HP Pavilion g4-1117dx Screen Replacement: adım 5, 2 resimden 1. HP Pavilion g4-1117dx Screen Replacement: adım 5, 2 resimden 2.
    • Remove four 4.0mm JIS #0 screws located at each corner of the monitor.
  5. HP Pavilion g4-1117dx Screen Replacement: adım 6, 3 resimden 1. HP Pavilion g4-1117dx Screen Replacement: adım 6, 3 resimden 2. HP Pavilion g4-1117dx Screen Replacement: adım 6, 3 resimden 3.
    • Remove the two silver hinge covers.
  6. HP Pavilion g4-1117dx Screen Replacement: adım 7, 2 resimden 1. HP Pavilion g4-1117dx Screen Replacement: adım 7, 2 resimden 2.
    • Unplug at golden connector.
  7. HP Pavilion g4-1117dx Screen Replacement: adım 8, 3 resimden 1. HP Pavilion g4-1117dx Screen Replacement: adım 8, 3 resimden 2. HP Pavilion g4-1117dx Screen Replacement: adım 8, 3 resimden 3.
    • Remove four 3.0mm JIS #0 screws, two on each side of the screen.
  8. HP Pavilion g4-1117dx Screen Replacement: adım 9, 1 resimden 1.
    • Carefully remove the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Hamilton
1.165 İtibar
10 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 UMass Dartmouth, Team S2-G7, Simcock Spring 2018 üyesi
UMASSD-SIMCOCK-S18S2G7
4 Üyeler
Bir Yorum
nice very informative
S i n o for pc - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 15
Her zaman: 789
