Ana içeriğe geç
HP Pavilion g6-1b79dx Bottom Panel Replacement
Neye ihtiyacın var
  1. HP Pavilion g6-1b79dx Bottom Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Bottom Panel Replacement: adım 2, 2 resimden 1. HP Pavilion g6-1b79dx Bottom Panel Replacement: adım 2, 2 resimden 2.
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Bottom Panel Replacement: adım 3, 2 resimden 1. HP Pavilion g6-1b79dx Bottom Panel Replacement: adım 3, 2 resimden 2.
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Bottom Panel Replacement, Bottom Panel: adım 4, 1 resimden 1.
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Bottom Panel Replacement: adım 5, 1 resimden 1.
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Bottom Panel Replacement: adım 6, 3 resimden 1. HP Pavilion g6-1b79dx Bottom Panel Replacement: adım 6, 3 resimden 2. HP Pavilion g6-1b79dx Bottom Panel Replacement: adım 6, 3 resimden 3.
    • With your hands, lift the panel completely off the base of the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Rachel Gallegos
873 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 10-12, Williams Fall 2015 Baylor, Team 10-12, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S10G12
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 1,968
