Ana içeriğe geç
HP Pavilion g6-1b79dx Speaker Replacement
Neye ihtiyacın var
  1. HP Pavilion g6-1b79dx Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Speaker Replacement: adım 2, 2 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 2, 2 resimden 2.
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Speaker Replacement: adım 3, 2 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 3, 2 resimden 2.
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Speaker Replacement, Bottom Panel: adım 4, 1 resimden 1.
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Speaker Replacement: adım 5, 1 resimden 1.
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Speaker Replacement: adım 6, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 6, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 6, 3 resimden 3.
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Speaker Replacement, RAM: adım 7, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement, RAM: adım 7, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement, RAM: adım 7, 3 resimden 3.
    • Slide the two latches away from the RAM to unhook it.
  8. HP Pavilion g6-1b79dx Speaker Replacement: adım 8, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 8, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 8, 3 resimden 3.
    • Gently slide the RAM out from the laptop.
  9. HP Pavilion g6-1b79dx Speaker Replacement, Hard Drive: adım 9, 2 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement, Hard Drive: adım 9, 2 resimden 2.
    • Use the PH 00 screwdriver to unscrew the 2.5 mm screw to the right of the hard drive.
  10. HP Pavilion g6-1b79dx Speaker Replacement: adım 10, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 10, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 10, 3 resimden 3.
    • Pull the triangular blue tab to diconnect and remove the hard drive. You can see the word 'Pull' on the cover.
  11. HP Pavilion g6-1b79dx Speaker Replacement, Wireless Card: adım 11, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement, Wireless Card: adım 11, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement, Wireless Card: adım 11, 3 resimden 3.
    • Unlatch the two antenna cable connectors from the wireless card.
  12. HP Pavilion g6-1b79dx Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the two 2.5 mm screws in the wireless card with a PH00 screwdriver.
    • You may have to gently bend the cables away from the wireless card to remove the screws
  13. HP Pavilion g6-1b79dx Speaker Replacement: adım 13, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 13, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 13, 3 resimden 3.
    • Gently disconnect the wireless card from the laptop.
  14. HP Pavilion g6-1b79dx Speaker Replacement, CD Drive: adım 14, 2 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement, CD Drive: adım 14, 2 resimden 2.
    • Using the PH 00 screwdriver, remove the screw left of the CD drive.
  15. HP Pavilion g6-1b79dx Speaker Replacement: adım 15, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 15, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 15, 3 resimden 3.
    • Slide the CD drive out from the exterior of the laptop.
  16. HP Pavilion g6-1b79dx Speaker Replacement, Keyboard: adım 16, 1 resimden 1.
    • Using a PH 00 screwdriver, remove the screw located next to the wireless card.
    • You can remove the wireless card for this process but it is not necessary.
    • This screw has a small keyboard icon next to it.
  17. HP Pavilion g6-1b79dx Speaker Replacement: adım 17, 1 resimden 1.
    • Flip the laptop over and open it.
    • The components beneath your computer may be loose and fall out when you flip the laptop. Be careful when turning it over.
  18. HP Pavilion g6-1b79dx Speaker Replacement: adım 18, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 18, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 18, 3 resimden 3.
    • Insert a plastic spudger or similar pry tool, beneath the keyboard, near the "insert" key, and pop the keyboard up from the laptop.
    • Starting at the opening you just created, run your fingers around the outside of the keyboard separating it from the rest of the computer.
    • Only lift the keyboard up a few inches because it is attached to the laptop by a ribbon cable.
  19. HP Pavilion g6-1b79dx Speaker Replacement: adım 19, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 19, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 19, 3 resimden 3.
    • Slightly angle the keyboard back so the ribbon connector underneath it is visible.
    • Remove the ribbon cable by using your fingers to pull up and away from the connector.
  20. HP Pavilion g6-1b79dx Speaker Replacement: adım 20, 1 resimden 1.
    • With the ribbon cable detached, you can now completely remove the keyboard.
  21. HP Pavilion g6-1b79dx Speaker Replacement, Speaker: adım 21, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement, Speaker: adım 21, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement, Speaker: adım 21, 3 resimden 3.
    • With the laptop bottom facing up, locate the rubber plug on the right side of the computer.
    • Use a metal splunger to remove the plug.
  22. HP Pavilion g6-1b79dx Speaker Replacement: adım 22, 1 resimden 1.
    • Remove the ten 6.7 mm screws using a PH00 screwdriver.
    • Remove the five 3.4 mm screws using a PH00 screwdriver.
  23. HP Pavilion g6-1b79dx Speaker Replacement: adım 23, 1 resimden 1.
    • Flip the computer over and open it.
    • Detach the two purple ribbons from the ribbon connectors.
    • Unscrew the six 4.6 mm screws using the PH00 screwdriver.
  24. HP Pavilion g6-1b79dx Speaker Replacement: adım 24, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 24, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 24, 3 resimden 3.
    • Use the plastic opening tool to pry out the front panel around the entire computer.
  25. HP Pavilion g6-1b79dx Speaker Replacement: adım 25, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 25, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 25, 3 resimden 3.
    • Gently lift the front panel away from the computer.
  26. HP Pavilion g6-1b79dx Speaker Replacement: adım 26, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 26, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 26, 3 resimden 3.
    • Locate the red and black speaker cables connecting the speakers and detach them from the two holders.
  27. HP Pavilion g6-1b79dx Speaker Replacement: adım 27, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 27, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 27, 3 resimden 3.
    • Pull the speaker cables out of their connectors.
  28. HP Pavilion g6-1b79dx Speaker Replacement: adım 28, 2 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 28, 2 resimden 2.
    • Slide the left speaker out from under the blue motherboard.
  29. HP Pavilion g6-1b79dx Speaker Replacement: adım 29, 3 resimden 1. HP Pavilion g6-1b79dx Speaker Replacement: adım 29, 3 resimden 2. HP Pavilion g6-1b79dx Speaker Replacement: adım 29, 3 resimden 3.
    • Lift the right speaker directly up and remove it from the computer.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Rachel Gallegos
873 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 10-12, Williams Fall 2015 Baylor, Team 10-12, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S10G12
3 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
I Love the practical very much
Mamadoumolo Jalloh - Yanıt
HP Pavilion g6 price
YASIR KHAN OFFICIAL - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 6,667
