Ana içeriğe geç
HP Pavilion g6-2228tx RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion g6-2228tx RAM Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion g6-2228tx RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx RAM Replacement, Hard Drive: adım 2, 2 resimden 1. HP Pavilion g6-2228tx RAM Replacement, Hard Drive: adım 2, 2 resimden 2.
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx RAM Replacement: adım 3, 3 resimden 1. HP Pavilion g6-2228tx RAM Replacement: adım 3, 3 resimden 2. HP Pavilion g6-2228tx RAM Replacement: adım 3, 3 resimden 3.
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx RAM Replacement: adım 4, 2 resimden 1. HP Pavilion g6-2228tx RAM Replacement: adım 4, 2 resimden 2.
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx RAM Replacement: adım 5, 2 resimden 1. HP Pavilion g6-2228tx RAM Replacement: adım 5, 2 resimden 2.
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
  6. HP Pavilion g6-2228tx RAM Replacement, RAM: adım 6, 2 resimden 1. HP Pavilion g6-2228tx RAM Replacement, RAM: adım 6, 2 resimden 2.
    • The silver hinges holds the RAM in place.
  7. HP Pavilion g6-2228tx RAM Replacement: adım 7, 2 resimden 1. HP Pavilion g6-2228tx RAM Replacement: adım 7, 2 resimden 2.
    • Use two fingers to push both silver hinges outward to release the RAM.
    • The released RAM will pop up.
  8. HP Pavilion g6-2228tx RAM Replacement: adım 8, 1 resimden 1.
    • Pull the RAM stick to the left and remove it from the device.
Sonuç
Hai Lin
446 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team S4-G6, Lore Fall 2018 UC Davis, Team S4-G6, Lore Fall 2018 üyesi
UCD-LORE-F18S4G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 649
