Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Push the battery latch to the left to release the battery.
Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
Place your hand on the cover and slide the cover down.
Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
Place one finger on the right side of the hard drive.
Push the hard drive to the left and lift the hard drive up to remove it from the device.
Disconnect the connecting part by pulling the part to the right.
Remove the hard drive from the device.
Use two fingers to push both silver hinges outward to release the RAM.
Pull the RAM stick to the left and remove it from the device.
