Ana içeriğe geç
HP Pavilion g7-1150us Optical Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion g7-1150us Optical Drive Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion g7-1150us Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Optical Drive Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Optical Drive Replacement, Surface Panel: adım 3, 1 resimden 1.
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Optical Drive Replacement: adım 4, 2 resimden 1. HP Pavilion g7-1150us Optical Drive Replacement: adım 4, 2 resimden 2.
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Optical Drive Replacement: adım 5, 1 resimden 1.
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us Optical Drive Replacement, Optical Drive: adım 6, 1 resimden 1.
    • Use the screwdriver to remove the 4mm Phillips #0 screw holding the optical drive in.
  7. HP Pavilion g7-1150us Optical Drive Replacement: adım 7, 1 resimden 1.
    • Use your fingers to grab the optical drive.
  8. HP Pavilion g7-1150us Optical Drive Replacement: adım 8, 1 resimden 1.
    • Pull out drive completely.
Sonuç
Cierra Sheerin
97 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G3, Peak Spring 2019 UMass Dartmouth, Team S6-G3, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G3
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
What do you do when the DVD drive will NOT slide out? That’s my problem. There’s no disk inside; the unit is simply stuck shut. Now what do you do?
paulwrites - Yanıt
For me, the DVD drive connection had, what I think was soda, inside of the port and it acted like a sort of glue so brute force may be the option.
After a deep cleaning of the connections, it worked like new.
Dylan Dopp -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 435
