Ana içeriğe geç
HP Pavilion g7-1150us Surface Panel Replacement
Neye ihtiyacın var
  1. HP Pavilion g7-1150us Surface Panel Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion g7-1150us Surface Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Surface Panel Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Surface Panel Replacement, Surface Panel: adım 3, 1 resimden 1.
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Surface Panel Replacement: adım 4, 2 resimden 1. HP Pavilion g7-1150us Surface Panel Replacement: adım 4, 2 resimden 2.
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Surface Panel Replacement: adım 5, 1 resimden 1.
    • Lift the pried surface panel off of the computer.
Sonuç
Kyle Dinunno
377 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G3, Peak Spring 2019 UMass Dartmouth, Team S6-G3, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 289
