Ana içeriğe geç
HP Pavilion g7-1365dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion g7-1365dx Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Hard Drive Replacement: adım 2, 1 resimden 1.
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Hard Drive Replacement, Service Door: adım 3, 2 resimden 1. HP Pavilion g7-1365dx Hard Drive Replacement, Service Door: adım 3, 2 resimden 2.
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. HP Pavilion g7-1365dx Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Disconnect the drive connector cable from the system board by pulling the plastic tab on top of the connector.
    • Use the opening tool to lift the hard drive out.
    • Remove the hard drive.
Sonuç
Derrick Manu
245 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 UMass Dartmouth, Team S1-G1, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 361
