Ana içeriğe geç
HP Pavilion g7-1365dx RAM Replacement
Neye ihtiyacın var
  1. HP Pavilion g7-1365dx RAM Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx RAM Replacement: adım 2, 1 resimden 1.
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx RAM Replacement, Service Door: adım 3, 2 resimden 1. HP Pavilion g7-1365dx RAM Replacement, Service Door: adım 3, 2 resimden 2.
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx RAM Replacement, RAM: adım 4, 2 resimden 1. HP Pavilion g7-1365dx RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Use your fingers to simultaneously pull apart both tabs holding the module.
    • The memory module will pop up once the tabs are pulled so that it can be removed.
  5. HP Pavilion g7-1365dx RAM Replacement: adım 5, 1 resimden 1.
    • Directly pull out the memory module as shown.
Sonuç
Rafal Szmyd
181 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 UMass Dartmouth, Team S1-G1, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 293
