Ana içeriğe geç
HP Pavilion g7-1368dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion g7-1368dx  Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx  Hard Drive Replacement: adım 2, 1 resimden 1.
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx  Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
  4. HP Pavilion g7-1368dx  Hard Drive Replacement: adım 4, 1 resimden 1.
    • Slide the service panel down and pull it up to remove.
  5. HP Pavilion g7-1368dx  Hard Drive Replacement: adım 5, 2 resimden 1. HP Pavilion g7-1368dx  Hard Drive Replacement: adım 5, 2 resimden 2.
    • Locate the hard drive.
    • It is missing from the device pictured here.
    • Disconnect the cable connector by pulling it away from the hard drive.
    • Remove the hard drive from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alana Spaeth
570 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 295
