Ana içeriğe geç
HP Pavilion g7-1368dx Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion g7-1368dx Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx Keyboard Replacement: adım 2, 1 resimden 1.
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
    • Slide the service panel down and pull it up to remove.
  4. HP Pavilion g7-1368dx Keyboard Replacement: adım 4, 1 resimden 1.
    • Remove the one 7 mm Phillips #1 screw securing the keyboard to the device.
  5. HP Pavilion g7-1368dx Keyboard Replacement: adım 5, 1 resimden 1.
    • Flip over the device and open the screen.
  6. HP Pavilion g7-1368dx Keyboard Replacement: adım 6, 2 resimden 1. HP Pavilion g7-1368dx Keyboard Replacement: adım 6, 2 resimden 2.
    • Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
    • Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
    • Disconnect the ribbon cable by sliding it out of the ZIF connector.
    • Remove the keyboard.
Sonuç
Kianna Young
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 269
