Giriş
There are a few reasons you may want to replace your optical drive. You lost the bezel (drive face), the optical drive doesn’t open, the optical drive no longer works, or you want to upgrade to a blue ray drive. Whatever the reason, this guide will show you how to replace the optical drive.
The parts listed in the guide include the compatible DVD and Blue-ray optical drives. The instructions in this guide work for replacing either optical drive in the device. You must decide which drive you want to replace in this optical drive location.
Neye ihtiyacın var
Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
Using a Phillips #0 screwdriver, remove the optical drive anchor screw.
