Ana içeriğe geç
HP Pavilion g7-2275dx Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion g7-2275dx Hard Drive Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: adım 1, 1 resimden 1.
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  2. HP Pavilion g7-2275dx Hard Drive Replacement: adım 2, 2 resimden 1. HP Pavilion g7-2275dx Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the back panel down and pull it up.
  3. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  4. HP Pavilion g7-2275dx Hard Drive Replacement: adım 4, 2 resimden 1. HP Pavilion g7-2275dx Hard Drive Replacement: adım 4, 2 resimden 2.
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
  5. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Remove the black SATA cable from the hard drive.
  6. HP Pavilion g7-2275dx Hard Drive Replacement: adım 6, 2 resimden 1. HP Pavilion g7-2275dx Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the black rubber end caps.
  7. HP Pavilion g7-2275dx Hard Drive Replacement: adım 7, 2 resimden 1. HP Pavilion g7-2275dx Hard Drive Replacement: adım 7, 2 resimden 2.
    • Remove the four silver 5 mm Phillips #1 screws from the hard drive.
  8. HP Pavilion g7-2275dx Hard Drive Replacement: adım 8, 1 resimden 1.
    • Remove the plastic cover from the hard drive.
Sonuç
To reassemble or replace your hard drive, follow these instructions in reverse order with the working drive.
5 farklı kişi bu kılavuzu tamamladı.
Erik Miller
2.123 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-51, Amido Spring 2014 Cal Poly, Team 11-51, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G51
4 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 4,975
