Giriş
Lost or wore out some of your keys? This guide will help you replace the keyboard on your laptop.
Neye ihtiyacın var
Unscrew one Phillips #1 screw from the back panel.
Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
Pull the keyboard up and away from you, as it is held in by clips in the front. It is not yet disconnected.
8 farklı kişi bu kılavuzu tamamladı.
3 Yorum
No hay información
Good guide. It helped me going quicker at getting to the keyboard. Thank you!
The keyboard for this computer is HP part number 640208-001 and it is not available anymore in HP. It is available in Amazon, however.
