Ana içeriğe geç
HP Pavilion g7-2275dx Wireless Card Replacement
Neye ihtiyacın var
  1. HP Pavilion g7-2275dx Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion g7-2275dx Wireless Card Replacement: adım 2, 1 resimden 1.
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. HP Pavilion g7-2275dx Wireless Card Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: adım 3, 1 resimden 1.
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. HP Pavilion g7-2275dx Wireless Card Replacement: adım 4, 2 resimden 1. HP Pavilion g7-2275dx Wireless Card Replacement: adım 4, 2 resimden 2.
    • Slide the back panel down and pull it up.
  5. HP Pavilion g7-2275dx Wireless Card Replacement, Wireless Card: adım 5, 1 resimden 1.
    • Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
  6. HP Pavilion g7-2275dx Wireless Card Replacement: adım 6, 2 resimden 1. HP Pavilion g7-2275dx Wireless Card Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool to lift the wireless card out of its slot.
  7. HP Pavilion g7-2275dx Wireless Card Replacement: adım 7, 2 resimden 1. HP Pavilion g7-2275dx Wireless Card Replacement: adım 7, 2 resimden 2.
    • Pull the black and white wires up and off of the wireless card.
    • Remove the wireless card.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
John Sutton
1.566 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-51, Amido Spring 2014 Cal Poly, Team 11-51, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G51
4 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 2,218
