Ana içeriğe geç
HP Pavilion p6 Wireless Card Replacement
Neye ihtiyacın var
  1. HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: adım 1, 3 resimden 1. HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: adım 1, 3 resimden 2. HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: adım 1, 3 resimden 3.
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
  2. HP Pavilion p6 Wireless Card Replacement: adım 2, 3 resimden 1. HP Pavilion p6 Wireless Card Replacement: adım 2, 3 resimden 2. HP Pavilion p6 Wireless Card Replacement: adım 2, 3 resimden 3.
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
  3. HP Pavilion p6 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 1. HP Pavilion p6 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 2. HP Pavilion p6 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 3.
    • First locate the wireless card, it should look like this.
    • Next using a spudger or equivalent carefully pry the antenna cable off the wireless card, it should now look like the second picture.
    • A single screw then needs to be removed in order to free the card.
  4. HP Pavilion p6 Wireless Card Replacement: adım 4, 2 resimden 1. HP Pavilion p6 Wireless Card Replacement: adım 4, 2 resimden 2.
    • The card can then just be easily removed by pulling it out and up.
    • The wireless card should then be kept in a safe place and care taken not to lose the small screw that goes with it.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Oli
1.310 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 2,621
