Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
In order to remove the side panel a single screw needs to first be removed.
First locate the wireless card, it should look like this.
Next using a spudger or equivalent carefully pry the antenna cable off the wireless card, it should now look like the second picture.
A single screw then needs to be removed in order to free the card.
The card can then just be easily removed by pulling it out and up.
7 farklı kişi bu kılavuzu tamamladı.
