Ana içeriğe geç
HP Pavilion tx2500 Screen Rotator Replacement
Neye ihtiyacın var
  1. HP Pavilion tx2500 Screen Rotator Replacement, Screen Rotator: adım 1, 1 resimden 1.
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
  2. HP Pavilion tx2500 Screen Rotator Replacement: adım 2, 2 resimden 1. HP Pavilion tx2500 Screen Rotator Replacement: adım 2, 2 resimden 2.
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
  3. HP Pavilion tx2500 Screen Rotator Replacement: adım 3, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
  4. HP Pavilion tx2500 Screen Rotator Replacement: adım 4, 1 resimden 1.
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
  5. HP Pavilion tx2500 Screen Rotator Replacement: adım 5, 1 resimden 1.
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
  6. HP Pavilion tx2500 Screen Rotator Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool to disconnect the wires in the upper corners.
  7. HP Pavilion tx2500 Screen Rotator Replacement: adım 7, 1 resimden 1.
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
  8. HP Pavilion tx2500 Screen Rotator Replacement: adım 8, 1 resimden 1.
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
  9. HP Pavilion tx2500 Screen Rotator Replacement: adım 9, 2 resimden 1. HP Pavilion tx2500 Screen Rotator Replacement: adım 9, 2 resimden 2.
    • Rotate the screen 90 degrees and remove the base under the screen.
  10. HP Pavilion tx2500 Screen Rotator Replacement: adım 10, 1 resimden 1.
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
  11. HP Pavilion tx2500 Screen Rotator Replacement: adım 11, 2 resimden 1. HP Pavilion tx2500 Screen Rotator Replacement: adım 11, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
  12. HP Pavilion tx2500 Screen Rotator Replacement: adım 12, 1 resimden 1.
    • Gently lift up and remove the screen.
Sonuç
Sarah Naiser
324 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 648
