Ana içeriğe geç
HP Pavilion x2 10-n113dx Hinge Replacement
Neye ihtiyacın var
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: adım 1, 2 resimden 1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: adım 1, 2 resimden 2.
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: adım 2, 2 resimden 1. HP Pavilion x2 10-n113dx Hinge Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: adım 3, 1 resimden 1.
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: adım 4, 2 resimden 1. HP Pavilion x2 10-n113dx Hinge Replacement: adım 4, 2 resimden 2.
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: adım 5, 3 resimden 1. HP Pavilion x2 10-n113dx Hinge Replacement: adım 5, 3 resimden 2. HP Pavilion x2 10-n113dx Hinge Replacement: adım 5, 3 resimden 3.
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: adım 6, 2 resimden 1. HP Pavilion x2 10-n113dx Hinge Replacement: adım 6, 2 resimden 2.
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: adım 7, 1 resimden 1.
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: adım 8, 1 resimden 1.
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: adım 9, 3 resimden 1. HP Pavilion x2 10-n113dx Hinge Replacement: adım 9, 3 resimden 2. HP Pavilion x2 10-n113dx Hinge Replacement: adım 9, 3 resimden 3.
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: adım 10, 3 resimden 1. HP Pavilion x2 10-n113dx Hinge Replacement: adım 10, 3 resimden 2. HP Pavilion x2 10-n113dx Hinge Replacement: adım 10, 3 resimden 3.
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
Sonuç
Ajay Panuganti
181 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S1G4
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,124
