Giriş
Use this guide to replace the speakers in your device.
Neye ihtiyacın var
Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
To unscrew the first speaker, use the Phillips #0 screwdriver to unscrew the 2 screws- head 3.99mm, length 3.32 mm.
Neredeyse bitti!
Sonuç
