Ana içeriğe geç
HP Pavilion x2 10-n113dx Touch Pad Replacement
Neye ihtiyacın var
  1. HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: adım 1, 2 resimden 1. HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: adım 1, 2 resimden 2.
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Loosen the adhesive under the gray plastic bar using a heat pad or a heat gun.
    • Remove the gray plastic bar after 5 minutes of light heat with tweezers by pulling up.
  3. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 3, 1 resimden 1.
    • Remove the 4 screws with a Phillips #0 screwdriver.
    • These 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 4, 2 resimden 1. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 4, 2 resimden 2.
    • Remove the rubber stoppers at the top left and right with tweezers.
    • Remove the screws at the top and right with at Phillips #0 screwdriver.
    • These two screws have a diameter of 5.3 mm and a height of 4.3 mm.
  5. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 5, 3 resimden 1. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 5, 3 resimden 2. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 5, 3 resimden 3.
    • Pry open the back case with a metal spudger.
    • Then pry open the back layer with the metal spudger.
  6. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 6, 2 resimden 1. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 6, 2 resimden 2.
    • Fully take off the back panel by lifting up the panel.
  7. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 7, 2 resimden 1. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 7, 2 resimden 2.
    • Pop open the ribbon cable piece on the touch pad with the blue plastic spudger.
    • Remove the ribbon cable with tweezers by pulling it out.
  8. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 8, 2 resimden 1. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 8, 2 resimden 2.
    • Remove 4 screws with at Phillips #0 screwdriver. All 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
    • Lift the tape shown with orange boxes with tweezers.
    • Remove metal bar with a blue spudger.
  9. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 9, 3 resimden 1. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 9, 3 resimden 2. HP Pavilion x2 10-n113dx Touch Pad Replacement: adım 9, 3 resimden 3.
    • Lift up the touch pad by the metal edge with a blue plastic spudger.
    • Remove the touch pad from the computer.
Sonuç
Cayla Skaggs
337 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S1G4
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 705
