Ana içeriğe geç
HP Pavilion x360 11-p110nr Hard Drive Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 11-p110nr  Hard Drive  Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  2. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: adım 2, 1 resimden 1.
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion x360 11-p110nr.
    • Remove the nine screws from the back panel using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: adım 3, 1 resimden 1.
    • Remove the four screws holding in the hard drive compartment using a Phillips #0 screwdriver.
    • Pull the hard drive up and out to remove it from the compartment.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,978
