Ana içeriğe geç
HP Pavilion x360 11-p110nr Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: adım 1, 2 resimden 2.
    • First, unplug the power cord from the power outlet and disconnect the charger.
    • Flip over the laptop.
    • Unscrew the back cover using the Phillips #0 screwdriver.
    • Deattach the cover carefully and do not remove the cover completely as there is a safety plastic that needs to be removed first.
    • Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
  2. HP Pavilion x360 11-p110nr Battery Replacement: adım 2, 2 resimden 1. HP Pavilion x360 11-p110nr Battery Replacement: adım 2, 2 resimden 2.
    • Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr Battery Replacement: adım 3, 1 resimden 1.
    • Carefully disconnect the three connectors by pulling them away from the slot.
    • If they seem hard to pull, try to wiggle them loose to making it easier to pull.
    • Pull out the battery after everything is disconnected.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 586
