Ana içeriğe geç
HP Pavilion x360 11-p110nr Charging Port Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 11-p110nr Charging Port Replacement, Charging Port: adım 1, 3 resimden 1. HP Pavilion x360 11-p110nr Charging Port Replacement, Charging Port: adım 1, 3 resimden 2. HP Pavilion x360 11-p110nr Charging Port Replacement, Charging Port: adım 1, 3 resimden 3.
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Carefully take the bottom cover off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 2, 3 resimden 1. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 2, 3 resimden 2. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 2, 3 resimden 3.
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Lift the small black flap holding the cable to the motherboard, and remove the cable.
    • The bottom plate can now be safely removed.
  3. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 3, 3 resimden 1. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 3, 3 resimden 2. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 3, 3 resimden 3.
    • Remove the large cable connecting the battery to the main board
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the charging port could also lead to risk of electrocution.
  4. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 4, 3 resimden 1. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 4, 3 resimden 2. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 4, 3 resimden 3.
    • Unplug the charging port at the top left of the laptop.
    • During reassembly, this can be reinserted before reapplying the shielding that will be removed in the next steps.
  5. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 5, 3 resimden 1. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 5, 3 resimden 2. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 5, 3 resimden 3.
    • Using a Phillips #0 screwdriver, unscrew the 5.6mm screw on top connecting the shielding to the board.
    • Using a Phillips #0 screwdriver, unscrew the 3.2mm screw on the bottom connecting the shielding to the board.
  6. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 6, 3 resimden 1. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 6, 3 resimden 2. HP Pavilion x360 11-p110nr Charging Port Replacement: adım 6, 3 resimden 3.
    • Lift the hinge.
    • Remove the long shielding that was under the hinge.
    • Remove and replace the charging port.
Sonuç
Aeorrell
433 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Spring 2023 IUPUI, Team 1-2, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 171
