Ana içeriğe geç
HP Pavilion x360 11-p110nr Key Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 11-p110nr Key Replacement, Key: adım 1, 1 resimden 1.
    • Use a screwdriver or other flat instrument to get under the key, and pull up slightly on one of the edges.
  2. HP Pavilion x360 11-p110nr Key Replacement: adım 2, 3 resimden 1. HP Pavilion x360 11-p110nr Key Replacement: adım 2, 3 resimden 2. HP Pavilion x360 11-p110nr Key Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Clear out any obstructions or crumbs that are jamming the key or the hinges underneath.
    • You may use a Q-tip, toothpick, or tweezers.
  3. HP Pavilion x360 11-p110nr Key Replacement: adım 3, 2 resimden 1. HP Pavilion x360 11-p110nr Key Replacement: adım 3, 2 resimden 2.
    • Use the flat screw to put the key back into place.
    • Gently press the key down. It should snap back into place
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 3,308
