Ana içeriğe geç
HP Pavilion x360 11-p110nr Speakers Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: adım 1, 3 resimden 1. HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: adım 1, 3 resimden 2. HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: adım 1, 3 resimden 3.
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Carefully take the bottom cover off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Speakers Replacement: adım 2, 3 resimden 1. HP Pavilion x360 11-p110nr Speakers Replacement: adım 2, 3 resimden 2. HP Pavilion x360 11-p110nr Speakers Replacement: adım 2, 3 resimden 3.
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Speakers Replacement: adım 3, 3 resimden 1. HP Pavilion x360 11-p110nr Speakers Replacement: adım 3, 3 resimden 2. HP Pavilion x360 11-p110nr Speakers Replacement: adım 3, 3 resimden 3.
    • Remove the large cable connecting the battery to the main board
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  4. HP Pavilion x360 11-p110nr Speakers Replacement: adım 4, 3 resimden 1. HP Pavilion x360 11-p110nr Speakers Replacement: adım 4, 3 resimden 2. HP Pavilion x360 11-p110nr Speakers Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Locate the cable for the speakers and unplug, as shown.
    • If needed, use the tweezers to gently remove the cable from its connector.
  5. HP Pavilion x360 11-p110nr Speakers Replacement: adım 5, 3 resimden 1. HP Pavilion x360 11-p110nr Speakers Replacement: adım 5, 3 resimden 2. HP Pavilion x360 11-p110nr Speakers Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the four 5.8 mm screws from the speakers.
    • The speakers are now not secured to the laptop.
  6. HP Pavilion x360 11-p110nr Speakers Replacement: adım 6, 3 resimden 1. HP Pavilion x360 11-p110nr Speakers Replacement: adım 6, 3 resimden 2. HP Pavilion x360 11-p110nr Speakers Replacement: adım 6, 3 resimden 3.
    • Lift each speaker out of the laptop.
    • Carefully remove each speaker.
    • The speakers are connected to each other by a wire.
Sonuç
Aeorrell
433 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Spring 2023 IUPUI, Team 1-2, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 72
