Giriş
This guide helps you to replace your speakers on your HP laptop using only a screwdriver, tweezers, and the replacement part. The entire process is fairly quick and easy, and with a bit of care, it can be completed safely at home.
Caution: Anytime you are working with batteries or power, be sure to take care around the electricity and always unplug the battery before you attempt to replace the port.
Neye ihtiyacın var
Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
Carefully take the bottom cover off.
