Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Lay the HP Pavilion top-down with the front edge facing towards you.
Remove the three 4.8mm Phillips #0 screws from the front side.
Using a plastic spudger, remove the grey silicon strip closest to the back-side.
Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
Using a spudger, pry off the black keyboard panel.
Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
Remove the five 4.6mm Phillips #1 screws located around the battery.
Using a spudger for assistance, lift up the right edge of the battery.
Remove the battery.
Using your fingernail, disconnect the ZIF (zero insertion force) hard drive cable by flipping up the small locking flap.
With your fingernails, disconnect the speaker cable from the motherboard by pulling back on the connector.
Remove the four 6.2mm Phillips #1 screws around the speakers.
Using your fingernail, disconnect the ZIF (zero insertion force) power button connector cable from the motherboard.
Using your fingernail, disconnect the ZIF display panel connector cable from the motherboard.
Disconnect the two WLAN antenna cables by sliding under the cable with a spudger, then lifting straight up.
Using your fingernail, disconnect the ZIF display touch screen connector cable from the motherboard.
Using your fingernails, disconnect the power connector cable by pulling straight out.
Remove the eleven 4.6 mm Phillips #1 screws from around the motherboard.
Remove the one 2.2 mm Phillips #1 broad head screw in the WLAN module.
Lift the motherboard up on the right side. Then, gently pull the motherboard straight out to the right.
Loosen the four captive Phillips #1 screws.
Flip the heat sink up.
Using a tissue or paper towel, clean thermal paste off the heat sink and processor.
Remove the black electric tape attached to the shell of the memory module.
