Ana içeriğe geç
HP Pavilion x360 11m-ad013dx Motherboard Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 11m-ad013dx Motherboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Lay the HP Pavilion top-down with the front edge facing towards you.
  2. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the three 4.8mm Phillips #0 screws from the front side.
  3. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 3, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 3, 2 resimden 2.
    • Using a plastic spudger, remove the grey silicon strip closest to the back-side.
  4. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the three 5.7mm Phillips #1 screws.
  5. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 5, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 5, 2 resimden 2.
    • Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
    • Using a spudger, pry off the black keyboard panel.
    • This step requires force to unclasp the latches keeping the keyboard in place.
  6. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 6, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 6, 2 resimden 2.
    • Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
    • You may disconnect the other end of the cable, for ease of access to other parts. Keep in mind that the end labeled MB connects to the motherboard.
  7. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 7, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 7, 2 resimden 2.
    • Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
  8. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the keyboard.
  9. HP Pavilion x360 11m-ad013dx Motherboard Replacement, Battery: adım 9, 1 resimden 1.
    • Remove the five 4.6mm Phillips #1 screws located around the battery.
  10. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 10, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 10, 2 resimden 2.
    • Using a spudger for assistance, lift up the right edge of the battery.
    • Remove the battery.
  11. HP Pavilion x360 11m-ad013dx Motherboard Replacement, Speaker: adım 11, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement, Speaker: adım 11, 2 resimden 2.
    • Using your fingernail, disconnect the ZIF (zero insertion force) hard drive cable by flipping up the small locking flap.
  12. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 12, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 12, 2 resimden 2.
    • With your fingernails, disconnect the speaker cable from the motherboard by pulling back on the connector.
    • Do not directly pull on the wires, as this can damage the connector.
  13. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 13, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 13, 2 resimden 2.
    • Lift the speaker cable from its retention chamber.
  14. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the four 6.2mm Phillips #1 screws around the speakers.
  15. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the speakers.
  16. HP Pavilion x360 11m-ad013dx Motherboard Replacement, Motherboard: adım 16, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement, Motherboard: adım 16, 2 resimden 2.
    • Using your fingernail, disconnect the ZIF (zero insertion force) power button connector cable from the motherboard.
  17. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 17, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 17, 2 resimden 2.
    • Using your fingernail, disconnect the ZIF display panel connector cable from the motherboard.
  18. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 18, 3 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 18, 3 resimden 2. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 18, 3 resimden 3.
    • Disconnect the two WLAN antenna cables by sliding under the cable with a spudger, then lifting straight up.
    • The black labeled cable inserts into the "A" connection. The white labeled cable inserts into the "B" connection.
  19. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 19, 3 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 19, 3 resimden 2. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 19, 3 resimden 3.
    • Using your fingernail, disconnect the ZIF display touch screen connector cable from the motherboard.
  20. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 20, 2 resimden 1. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 20, 2 resimden 2.
    • Using your fingernails, disconnect the power connector cable by pulling straight out.
    • Do not directly pull the wires, as this can damage the connector. Instead, pull on the white, plastic part of the connector.
  21. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 21, 1 resimden 1.
    • Remove the eleven 4.6 mm Phillips #1 screws from around the motherboard.
  22. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 22, 1 resimden 1.
    • Remove the one 2.2 mm Phillips #1 broad head screw in the WLAN module.
  23. HP Pavilion x360 11m-ad013dx Motherboard Replacement: adım 23, 1 resimden 1.
    • Lift the motherboard up on the right side. Then, gently pull the motherboard straight out to the right.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,113
