Giriş
Below you will find the steps to replace the motherboard for the HP Pavilion x360 11m-ad013dx. Whether you want to upgrade your laptop’s performance or your motherboard is malfunctioning, follow these steps to replace the motherboard. The motherboard, also known as the system board, is a main part of the system, containing the WLAN module, PSU, and memory module. The motherboard also provides access to the heat sink, located on the backside of the motherboard. Be careful when handling the motherboard, as some parts may be delicate.
Neye ihtiyacın var
Using your fingernail, disconnect the ZIF (zero insertion force) hard drive cable by flipping up the small locking flap.
Using your fingernail, disconnect the ZIF (zero insertion force) power button connector cable from the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
