Ana içeriğe geç
HP Pavilion x360 14-ba253cl Keyboard Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14-ba253cl Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Keyboard Replacement: adım 3, 1 resimden 1.
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Keyboard Replacement: adım 4, 1 resimden 1.
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Keyboard Replacement: adım 5, 1 resimden 1.
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kristen Gismondi
82.362 İtibar
200 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.303 adet Kılavuz yazıldı
Bir Yorum
Kristen, How is the keyboard mounted to the top panel?
Larry Levy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 74
Her zaman: 6,998
