Ana içeriğe geç
HP Pavilion x360 14m-ba011dx Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion x360 14m-ba011dx Battery Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion x360 14m-ba011dx Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Two 7.5 mm screws.
    • Three 5 mm screws.
    • One 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Battery Replacement: adım 2, 1 resimden 1.
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Battery Replacement: adım 3, 2 resimden 1. HP Pavilion x360 14m-ba011dx Battery Replacement: adım 3, 2 resimden 2.
    • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx Battery Replacement: adım 4, 2 resimden 1. HP Pavilion x360 14m-ba011dx Battery Replacement: adım 4, 2 resimden 2.
    • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
    • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery by gently pushing battery up, then pulling.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 46
Her zaman: 2,835
