Giriş
Before using this guide, make sure to review the troubleshooting page for the HP Pavilion x360 14m-ba011dx. The battery may not actually need to be replaced depending on the problem, which is why it is good to trouble shoot first.
With this guide, the user will be able to remove and replace the battery of the HP Pavilion x360 14m-ba011dx. The model number for this device is 1KT47UA. A battery replacement may be needed if your laptop is overheating or you are having difficulties booting the laptop up. The battery itself is only one large cell that is not adhered to any surface.
Make sure to turn off your computer and discharge the battery before starting this guide. By draining the battery before removing it, you reduce the risk of potential fires. ''
Neye ihtiyacın var
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Two 7.5 mm screws.
Three 5 mm screws.
One 6.5 mm screw.
3 farklı kişi bu kılavuzu tamamladı.
